FAQ: How to format CSV Files for GOTOES.
Posted: Thu Apr 20, 2023 6:28 pm
Uploading CSV File Rules
Delimeter
I have tried to make the CSV file upload as flexible as possible. Your CSV File can be either comma or tab delimted.
Column Headers
The first line of your file MUST have the column headers. They can be in any order. You MUST have one and only one header named "Timestamp". This is case-insensitive. The tool looks for partial matches, so "ele" or "elevation" or "alt" or "altitude" will all count for your elevation profile. Accepted types are Latitude, Longitude, Power, Cadence, Heart Rate, Temperature, Distance.
Table
Any Empty Values will be converted to zero.
Example of a Valid CSV File:
Example of a valid CSV file for GOTOES.
Download A Sample:
Click Here to Download a Simple CSV Template... or Click Here to Download an Advanced CSV Template
**Note that not all of the fields that you see implemented in the Advanced Template can be parsed into FIT files yet. I'm still working on that!
