output file wrong date?
Posted: Sat Nov 08, 2025 9:35 pm
by winner214
My watch went awol during the run and did all sorts of weird stuff, so not sure if it's the source file, but i tried to merge it with a gpx file i created of the route. The gotoes section all shows Nov 8, but when uploaded to strava, it has Nov 7 date and over 25 hours on the run!
Am i doing something totally wrong or is it something else?
thank you!
Re: output file wrong date?
Posted: Sat Nov 08, 2025 11:16 pm
Thanks for the question..
Your first screenshot is missing part of the upper portion of the screen. I would like to know if you used the "autodetect time zone" option which is shown at the top of the page. Moreover, are you sure that you selected the correct time zone when uploading your files?
If that is the issue, please enter the correct timezone to fix the problem.
If that is NOT the issue, please upload both of your source files to this forum and I will investigate why the time stamps do not match.
Posted: Tue Nov 11, 2025 4:25 am
by winner214
Thanks for getting back to me. I did select my time zone, but i was having all sorts of issues and wonder if it is because I was travelling across time zones.
In any case, I used the time shift tool to get something close enough which works as its a training run. Thanks again for building a great tool!
Posted: Wed Nov 12, 2025 7:32 pm
Yes, it is VERY likely that having the wrong file date could be related to you traveling across multiple time zones. That would absolutely explain this one-off issue, which is not related to GOTOES but rather the multiple time zones. If you see it again (without the timezone travel) please report back.
