Merged Distance not correct.
Posted: Wed Nov 25, 2020 6:12 pm
by GotoesUser
On my files I had distance of 25.56 and .70 however when going to Strava is showing 26.09 which is incorrect
Re: Merged Distance not correct.
Posted: Wed Nov 25, 2020 6:13 pm
You will want to select the “TCX” export option. Then select “Use embedded distance”. This will put the distance from your original files into the output file.
