Merged Distance not correct.
On my files I had distance of 25.56 and .70 however when going to Strava is showing 26.09 which is incorrect
Re: Merged Distance not correct.
You will want to select the “TCX” export option. Then select “Use embedded distance”. This will put the distance from your original files into the output file.
