How to Convert FIT, GPX, TCX, or CSV files to KML
The GOTOES tool is a good way to convert between file types. If you have a FIT, GPX, TCX, or CSV file that HAS TIMESTAMPS, you can now convert it to KML using the GOTOES tools.
How to Convert a FIT, CSV, GPX or TCX file that has timestamps
Select "KML" if you would like to convert a GPX or FIT or TCX or CSV file to KML.
Note that if your file does not already have timestamps, you will get an error upon upload. In that case, you need to add timestamps yourself:
How to Convert a FIT, CSV, GPX or TCX file that DOES NOT HAVE timestamps Hope that helps you convert between different GPS file formats!
