ConnectIQ data not found in .FIT file created by Garmin device
Posted: Wed May 31, 2023 7:50 pm
I am using your excellent tool in two ways
The original activities include ConnectIQ data (flow & grit). The post-merge activities do not have the ConnectIQ data.
I select "FIT" as the output file format. When I select the "ConnectIQ" input stream I get a popup with the error: "No Developer Data found in file", and the "ConnectIQ" checkbox gets annotated with "no valid data".
I saw that another user had posted a similar problem viewtopic.php?t=126 . In his case he was exporting data from a Garmin Forerunner 735XT. Your answer was:
I tried to attach a copy of the incoming .FIT file, but it is a dis-allowed file type.
Thanks for taking the time to read this, I am a big fan of your tool!
- to merge 2 activities created by a Garmin Edge 530 (accidently recorded separately)
- to merge an activity created by a Garmin Edge 530 with health data created by a Samsung watch
Based on your post "ConnectIQ fields not showing on Merge" viewtopic.php?t=141, I think your answer may be wrong. Your post explains that 3rd party apps must include an "application_id" (to supply the mapping to the field_defintion_number), but I suspect that is not true for Garmin's own apps. If your tool is checking for the presence of the application_id (and triggering the "No Developer Data found" error if it's not there), it may fail to detect the presence of ConnectIQ data in a .FIT file generated by a Garmin app.It’s not really an error. It simply means that your file doesn’t have any of the special ConnectIQ fields present.
