Add GPS locations to TCX from GPX/KML
marwis
Post by marwis »
Sometimes my watch does not record GPS location but the resulting TCX file is otherwise complete with many trackpoints having distance, speed, cadence and heartrate, e.g.:
<Trackpoint><Time>2023-08-18T19:02:44.944Z</Time><HeartRateBpm><Value>106</Value></HeartRateBpm></Trackpoint>
<Trackpoint><Time>2023-08-18T19:02:45.402Z</Time><DistanceMeters>100.921</DistanceMeters><Cadence>85</Cadence><ns3:TPX><Speed>3.61</Speed></ns3:TPX></Trackpoint>
<Trackpoint><Time>2023-08-18T19:02:45.944Z</Time><HeartRateBpm><Value>107</Value></HeartRateBpm></Trackpoint>
I happen to have GPS route in KML/GPX format and would like to add points from it into TCX.
Ideally the points would get their timestamps calculated based on speed recorded in TCX.
When I try to upload TCX+GPX to Combine Tool, it seems to completely ignore GPX file. Is this a bug?
If I use Add Timestamp tool then I have to provide desired speed and it will recalculate everything ignoring speed and timestamps from TCX (kind of makes sense for add timestamp tool). It will also discard heart rate.
Is this a supported scenario?
marwis
Re: Add GPS locations to TCX from GPX/KML
Post by marwis »
Forgot to mention GPX/KML track has no timestamps.
Ah yes… you need to add the time stamps to the GPX first. Then it will show. This is the tool you need:
https://gotoes.org/strava/Add_Timestamps_To_GPX.php
I re-read your question (was climbing on my bike when I first read it)… now I understand better. What you are asking is not supported by the tool (yet). I’m now trying to thing about two things:
1) Does anyone else have this scenario (to make it worth my time to add such feature) and…
2) How would I do this… it might need to be a separate tool. I do already have a « generate fake track » option, so I will have to see if maybe I can utilize that option to work with an existing GPX maybe….
marwis
Post by marwis »
fulmar2 wrote: Sun Aug 20, 2023 1:22 pm I re-read your question (was climbing on my bike when I first read it)… now I understand better. What you are asking is not supported by the tool (yet). I’m now trying to thing about two things:
Thanks for taking the time!
fulmar2 wrote: Sun Aug 20, 2023 1:22 pm 1) Does anyone else have this scenario (to make it worth my time to add such feature) and…
I kind of expected it to work when uploading tcx + gpx (resulting in either generated track for gpx or enrichment of tcx points with interpolated positions) but even a separate tool would be great too.
