Some Garmin Activities not Appearing on Gotoes
A place for the community to help each other out with getting the most out of the Transfer Activities from Garmin Connect To Strava Tool.
pedrojsoria
Post by pedrojsoria »
I have observed recently that some activities are not appearing on the Garmin to Strava tool.
I have the feeling that it is occuring with “short” activities, like under 10km. As an example, I recorded one day a ride in several parts and only “long” ones were present, while the shorter were missing.
Just in case it helps, today I recorded this one and is not appearing in Gotoes:
https://connect.garmin.com/modern/activity/18106530433
My gotoes user is pedrojsoria@gmail.com
Could you please help me to solve this?
Thanks!!
Pedro
Re: Some Garmin Activities not Appearing on Gotoes
This happens to me too. I didn’t consider it was short activities. I thought it was when two or more activities upload simultaneously to Garmin. Regardless, I have checked the logs and this is on Garmin’s end. Garmin sends the files to GOTOES listener page… only thing is that occasionally Garmin never sends them. Activity send trigger is once - when your file is uploaded, and Garmin does not try again if it fails. GOTOES is therefore completely unaware of the file. Best thing to do would be to contact Garmin and get them to improve their API. You will notice that the same thing happens occasionally with all other apps that Garmin ports to (including Strava). Sorry that I cannot fix this one.
pedrojsoria
Thanks a lot for your nice answer. I’ll contact Garmin then.
Best Regards,
Pedro
