FAQ: How to ZIP compress files on Windows/Mac/Mobile
Posted: Wed Jun 24, 2026 7:11 pm
How to Create a ZIP File on Windows or Mac
Quick Tutorial in one image:
Detailed Instructions on how to ZIP files:
ZIP files make it easier to upload large files to GOTOES.
Windows 11
Step 1: Find the files or folder
Open File Explorer and navigate to the files or folder you want to send.
To select more than one item:
Step 2: Create the ZIP file
Right-click one of the selected items and choose:
Compress to ZIP file
Right-click the selected files and choose “Compress to ZIP file.”
Windows will create a new file ending in .zip in the same folder.
Type a descriptive name for the ZIP file and press Enter.
For example:
Using Windows 10?
Right-click the selected files, then choose:
Send to → Compressed (zipped) folder
Mac
Step 1: Find and select the files
Open Finder and navigate to the files or folder you want to send.
Right-click the selected item or items.
If your mouse does not have a right-click button, hold the Control key while clicking.
Choose one of the following:
The ZIP file will appear in the same Finder folder.
When several files are selected, macOS may name the file Archive.zip. You can click the filename and give it a more descriptive name.
Frequently Asked Questions
Where did the ZIP file go?
It is normally created in the same folder as the original files.
Can I ZIP an entire folder?
Yes. Right-click the folder and use the same ZIP or Compress command.
Should I ZIP a file that already ends in .zip?
Usually not. Zipping an existing ZIP file rarely makes it smaller.
Why does my right-click menu look different?
Menu wording can vary slightly depending on the version of Windows or macOS. Programs such as WinZip, WinRAR, or 7-Zip can also add extra choices to the menu.
Quick Summary
Windows 11: Select files → Right-click → Compress to ZIP file
Windows 10: Select files → Right-click → Send to → Compressed (zipped) folder
Mac: Select files → Right-click or Control-click → Compress
Windows 11
- Hold Ctrl while clicking individual files.
- Use Shift to select a continuous group of files.
- You can also put everything into one folder and ZIP the entire folder.
For example:
myGPSfiles.zipRight-click the selected files, then choose:
Mac
- Hold the Command key while clicking individual files.
- You can also place everything into one folder and compress that folder.
- Compress “filename” when one item is selected.
- Compress X Items when several items are selected.
Quick Summary
