‼️‼️‼️‼️‼️‼️ NEW WEBSITE!!! ‼️‼️‼️‼️‼️‼️
Hey guys! As some of you know, a lot has been going on behind the scenes at GOTOES.
This past summer, GOTOES started getting hit with a sustained bot/DDoS problem that (unfortunately) has continued. I turned on Cloudflare protection, but the attackers quickly found ways around it by bypassing Cloudflare and hammering the origin directly. To stop that, I migrated to a higher-performance server and tightened things down hard: an extremely strict firewall on the server side, plus a much stricter “I am human” regime in Cloudflare.
Along the way I had some bad luck: the “fresh clean” server I was paying for was actually misconfigured, causing intermittent latency issues — which you may have noticed around January 1–12. I also had to put several formerly-free features behind a paywall to protect them from bot abuse.
That is not what I wanted. My goal is for GOTOES to stay “mostly free” so anyone can use it. But the bots were literally taking down the site on a daily basis. I still need donations to pay for the server (about $1300/year just in hosting), and that doesn’t include my time. For the last ~5 weeks I’ve basically been behind my computer 16–17 hours a day rewriting major parts of the site from scratch.
The purpose of this overhaul is twofold:
  1. Security / Lockdown: The bot attacks made it obvious the codebase needed to be much more locked down. I’ve added a very strict Content Security Policy (CSP), tightened the perimeter, and made a lot of changes aimed at making the site more resilient.
  2. FIT feature velocity: The previous architecture made it time-consuming to add or iterate on FIT file features. The revamp should let me move faster on esoteric feature requests. If you have a pending request I haven’t addressed yet, I’m sorry — my plan is to answer those requests once the migration is complete.
During the migration I’ve also streamlined the workflow, improved the GUI look & feel, and fixed some small bugs I didn’t even know existed.
Coming soon: the “flip the switch” moment
In the next couple weeks, we’re going to do a final cutover. There will be a minor disruption:
  1. Strava + Garmin reconnect required: All existing connections will be removed, and you’ll need to reconnect on the new system.
  2. Garmin auth upgrade: As part of the migration, GOTOES is moving to Garmin’s recently announced OAuth 2.0 / PKCE flow.
  3. Legacy site access: The legacy site will no longer be available except to donors. The idea is simple: if a donor has a critical workflow that isn’t yet covered in the new system, they can still roll back temporarily until their needs are addressed by the new site.
  4. Legacy site “freeze”: The legacy site will block new account creation, donations, and account changes — its state will be frozen. Tools should keep working for legacy donors, but Strava connections will effectively be per-site (connecting on the new site can disconnect the old one, and vice versa). Garmin connections on the legacy site will be blocked due to the auth changes.
  5. Critical: Please tell me immediately if you hit any issues on the new site. I’m aiming to fully sunset the legacy site about 1–2 weeks after the flip.
Thanks for using GOTOES — and thank you to everyone who’s donated, reported bugs, or been patient while I lock this thing down. I hope these changes help you get even more out of your GOTOES | Strava Tools!
