Strava only exports .json file format
- GotoesUser
Hi, I am trying to add heart rate data, recorded on an apple watch directly on strava app, to data from a tacx indoor trainer, also uploaded to strava via the tacx app. I have the TCX file format from the indoor trainers data downloaded from strava. The issue I am having is that the heart rate data can, it seems, only be taken from strava in .json file format. All other file formats are not available from the ellipsis, and the "export_tcx" addition to the HTML address line shows a text line that the "file cannot be exported". On a number of the files i have downloaded from strava as test it seems that most of them come in .JSON Maybe I'm missing a step some where! My question is, will .JSON be available to use in your tools in the future? Thanks
Re: Strava only exports .json file format
I have recently added a feature to connect directly to your Strava account. If you connect your Strava account to my tool, you will see your last 10 activities in Strava. You can check the checkbox and they will import into my tool. You can even mix and match - meaning that you can upload some files from your hard drive AND check a few boxes from your Strava list.
If you decide to use this option, make sure you select the "Randomize ID Tag" option on the 2nd page. This will allow you to upload (what appears to be) a duplicate activity to Strava.
