FAQ: How to combine separate activities into one MultiSport File (Triathlon or Duathlon)
Garmin Connect now allows users to record multisport activities (such as Triathlons and Duathlons) in one single file. Then, you can see the result as one single activity in Garmin Connect as displayed below:
When you click on any of the icons (circled in red in my screenshot), you can zoom to focus in on that segment of the activity in Garmin Connect. The entire activity can all be viewed on one page if you click the 3 ring icon. But what if you didn't start recording your activity as a "multisport", and instead manually created a separate activity for each leg of the triathlon? Now with GOTOES, you can put it all back together into one file. Here is how.
Load your files into GOTOES here. Click the "Choose Files" button to choose your individual activities in FIT, TCX, GPX, or CSV format. Then click the blue "Upload" Button.
Change the activity to "MultiSport" by going to the "Activity Type / Sport" Dropdown and selecting "MultiSport"
A window will pop up with options for each segment of the multisport activity. The tool should pre-populate the values as shown in the example below.
Simply choose the correct sport from the dropdown menu. I will change the first activity to "Swimming", the second to "Swim_To_Bike_Transition", and the forth to "Bike_To_Run_Transition"
Once everything has been corrected, you can now click the big blue "Submit" button at the bottom of the inner window.
Once you submit the page, the inner window should close, and you should see that "Multisport" has been added to each of your activities.
If you need to make any changes after-the-fact, you can always click on the link that says "(added)" and edit the values. Note that if you do this now, you will be looking at the raw, numerical data for these items.
Step 5:
In order for this to work, you will need to choose the "FIT" export format. FIT is the only file format capable of supporting true multisport activities. Finally, scroll to the bottom of the page and select "Click Here to combine GPS Files Using Above Parameters".
It is important to note: IF you do this for Strava, Strava will split up your activities again!! This is only for Garmin Connect and other platforms that support multisport files.
goingslowfast
Re: FAQ: How to combine separate activities into one MultiSport File (Triathlon or Duathlon)
Post by goingslowfast »
If we have a .fit file that is multisport (in my case from Apple Watch), can we change the split locations with Gotoes? The Apple watch clicked from T2 to run about 200m past the start of the run.
I tried changing the values in the purple circle here, but Gotoes doesn't seem to recompute the rest of the values.
Last edited by goingslowfast on Mon Oct 13, 2025 11:28 pm, edited 1 time in total.
Yes, probably. Can you please send me your file and tell me the TIME where the split should have happened (preferably in UTC, but if you don't know, I can convert from your local time zone). You can upload your file to this forum or you can use the contact form on GOTOES to start a thread.
goingslowfast
I tried the contact form, but couldn't upload there, so here it is again.
Out of curiosity what format are the timestamps in the multisport popup in? They look like epoch time, but pretty close to 20 years too early.
The timestamps for my workout in UTC would be:
Swim Start: October 5, 2025 1:21:20 PM
T1 Start: October 5, 2025 2:29:48 PM
Bike Start: October 5, 2025 2:44:53 PM
T2 Start: October 5, 2025 6:18:38 PM
Run Start: October 5, 2025 6:28:50 PM
Run Finish: October 5, 2025 9:19:51 PM
If you could help me edit those, that would be awesome! I couldn't seem to find a way to do it within the GOTOES UI. Thanks, Brian
Waco_Ironman_70_3.fit
(738.01 KiB) Downloaded 141 times
OH! Yeah, the way FIT file time is stored inside of the file… the RAW form is "FITTime = UnixTime - 631065600”
Sorry, should have noted that. Anyway, It looks like your file is not corrupted or anything… so actually, I might just be able to edit it with the Fit File Edit tool instead. This would result in minimal changes to your file. I am assuming you haven’t seen this tool yet:
https://gotoes.org/gotoes/strava/fitfileviewer.php
I made two versions. I noticed that this file was from Training Peaks? Anyway, it has a lot of “holes” in the data, so I patched those with V2.
For V1, however, I just used that tool I sent you earlier and patched in your UTC timestamps (AND also repaired the elapsed time for each session). I also changed the “activity” field to have 5 sessions, not one. I’m assuming that you edited this file in some other software? It has a couple issues that indicate it did not come directly from a device, unless that device bugged out.
So, attached is a V1 and a V2. If V2 has all the info you want, I would use that because it has been “patched”. If you want some esoteric FIT Fields that don’t show up in V1, you can go with V2. We can theoretically trim the end off the file if necessary as well, since your reported last time stamp did not match the end of your last session… but only if it is causing you a problem.
GOTOES_Edited_V2.fit
(791.25 KiB) Downloaded 128 times
GOTOES_Edited_V1.fit
(737.32 KiB) Downloaded 123 times
