Activity Privacy [Solved]
A place for users to submit feature requests that may benefit from a public discussion. Otherwise, please use the contact form to write me directly with your feature requests.
pedrojsoria
Post by pedrojsoria »
I don´t know if this would be possible, but it would be great to set Activity Privacy before sending it to Strava. I usually marc activities as private until I upload pictures. Now I use Transfer from Garmin Connect to Strava tool, go to Strava, and set it to private but it would be nice to skip that second step
Thanks a lot
Pedro
Re: Activity Privacy
I will look into seeing if the API allows this.. but I do the same as you… what I do is in Strava, I make the default for new activities to be private. Then, I use the Garmin to Strava tool to transfer files. I make edits on Strava (at my leisure) and then make some of them public. So, by setting the default privacy to private on Strava, I think that covers it and does not require any more “clicks” than if I added such a feature (supposing it is even possible) to gotoes. What do you think? Do you have a different use case that im not considering?
pedrojsoria
Hi again,
Thanks a lot for your nice and fast answer. To be honest, I didn’t know about that option, THANKS A LOT! That was the solution to my case. No need from my side then for m this feature.
Warm regards
Pedro
