Was exploring the Fit file viewer and noticed this one:
This string field takes the Garmin username
Unknown field identified
Re: Unknown field identified
Thanks for that. I can look into adding it, but I will need a test file so I know more about that field. Meanwhile, I'm more interested in resolving your other post, so test files for THAT post would be appreciated. I am guessing it is a "carry over" issue. GOTOES used to carry over empty fields differently, and I am aiming to come to a balance between filling in the gaps. (Scenario 1, you may have seen in the other user's heart rate file where GOTOES intentionally prevented the heart rate from going to zero during a pause, and the user did not like the flat line - too much filling empty data)... to not filling the gaps enough (your scenario)... Let's get that fixed and then I will add this data field.
Garmin Edge 840 FIT file attached
i122859945.fit- (133.22 KiB) Downloaded 48 times
OK, I added it as garmin_user_name. It's a provisional addition, so this field will not be used in export validation, but you will be able to see garmin_user_name* (the * indicates that it was a user supplied field name and not part of the official FIT spec). Thanks.
