Combining two GPX files from Komoot not working
steveb_online
Post by steveb_online »
Hi. Great tools.
I have created two route GPX files with Komoot which, when combined, are a race in 2021. I had to do two files as Komoot will not allow the route through a particular private road that is part of the race route. The files that I created have dates and times that overlap, so when I create the combined file, the routes go haywire and are not useable. So I have used the checkbox that allows the start and end times of the files to be adjusted. However, this also does not work as the second file (the one with the adjusted [later] start and end times) doesn't load now at all.
Suggestions welcomed, please
Re: Combining two GPX files from Komoot not working
Hi there Steve -
I'm not entirely sure I understand what you are trying to do, however you can upload your files to this forum if you want, with a better explanation. Alternatively you can use the contact form on the website to contact me, and I'll see what I can do to help you with your project.
