Distance not automatically showing on upload
britbarbie
Post by britbarbie »
When I select 2 activities that I recorded (one from my apple watch, one from an app that connects to the indoor bike at my gym) that I want to combine, the distance (which appears on strava) does not get pulled into the tool. I have to manually enter it on the gotoes combine page. How do I get it so it pulls it from strava when I upload the 2 to link together so I dont have to input it each time?
Re: Distance not automatically showing on upload
Can you please post the files with this issue? You can upload them to the forum.
britbarbie
https://strava.app.link/Zr0dx8ahtNb
This one has the distance and I’m trying to combine it with my Apple Watch which doesn’t have the distance;
https://strava.app.link/xvCfH5ehtNb
I’ve attached the raw data that I get from gotoes as well as the one from Strava
ICG_Open_Goal.fit
Strava export
(2.2 KiB) Downloaded 911 times
GOTOES_RawData_1325832495582537.csv
Gotoes export
(7.06 KiB) Downloaded 891 times
So, when you "pull from Strava" - does that mean that you are using Strava's download option and then loading the file into GOTOES... or are you using the orange bar in GOTOES to directly import from Strava?
Also, I looked at the ICG_Open_Goal file that you uploaded and it does not have distance embedded... so it would be impossible for GOTOEs to read that data because it is absent.
I also tried to look at the two links you have provided, but I think these might be private activities - because they aren't showing.
